PIXMA IP 7250
Hy my ip7250 printer the head hold on right side only even if you take it to the middle by force, it goes back to right side and stay the?Please help it New
When I print there are small black smudges equally spaced going horizontal. I have done all the cleaning of head and for clogs.
Im having an issue where everything that is in Times New Roman is double printing. This does not happen with arial font. Im confused, its on any software or browser and before anyone says i already have a good head alignment. Has someone had this iss...
My printer will print out copies from the computer but will not make copies from the printer. When I press the copy it makes a screeching noise and stops. Any suggestions?
Hello, Error 5100 comes up on my canon printer. I changed the low ink and there is no jams. It is MX439 printer. Can you help?
After a paper jam, printer canon MX452 has hard time pulling next page as well as blurred prints when it finally does
I have a paper jam in my printer, but cannot figure out how to open the back to find it.Can anyone help?
I have only used this printer a few times and only printed out about 30 items. I am now getting an error message with code number 1303 paper jammed in machine. I have checked everywhere and there is not a piece of paper or even a shred of paper anywh...
I set up an email agroup in Outlook and I'm trying to test it by scanning a document to the email address for that group. The scan to my individual email address works, but when I scan the same document to the group email address it doesn't go throu...
To save money, I drilled holes in the see-through ink containers in my Canon 5700 series printer. This resulted in plenty of warning messages that finally allowed me to disable the ink level warnings. I then drilled holes in the nearly empty ink wel...
My friend has given me his Canon Pixma E400 printer. I just installed it thru downloaded driver. It will print on Microsoft word but on Excel format. What's the problem?
I have a black line down the scanned page from the ADF Feeder in my MX920. It prints fine from the platen. I've cleaned the ADF several times. On the white bar in the ADF feeder there is a blackening, which looks like either ink or like the plastic h...
My faithful Canon iP7220 Printer suddenly started to misprint. All colors except BLACK print perfectly. New BLACK cardridge did not fix problem. Problem is: On text print out characters are duplicated a small fraction of an inch apart horizontally ...
My Canon Pixma MX922 won't connect to my wireless connection in my house. All my other wireless devices are working fine without any issues. It detects the wireless via WPS and manual set up but won't stay connected. My laptop will pick up the printe...
Hello - I am hoping someone can help me. I have a router Asus and I have the printer plugged int the router - rather than just a direct printer connection. I did not use the canon setup and instead set it up as an LPR server. I am able to print jus...
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
