PIXMA G3270 How to scan photos without using my PC
How do you SCAN photos on pixma G3270 photo printer /scanner,the instruction manual is worthless,can I scan without using my PC? I have the IJ scan utility in my apps,,HELP
I left a plate of pie and ice cream on top of the printer accidentally. (Got distracted and forget it) It melted and slopped over the plate into the printer under the glass. Can it be taken somewhere for repair or is it toast? Thanks.
hi i bought thr canon tr4651 printerand dont managge to scanwhat do i need to install to be possible to scan?
I have used my G7020 to successfully scan items from the flatbed ever since I got the printer months ago. The scanner is connected to my PC via my local network, which the printer shows as working OK. Now, when I try to scan using an application (inc...
I own the Cannon Pixma MG2520 printer/scanner. I think my problem might be the version of my MAC (Sonoma 14.3.1). I do not see this as one of the supported versions. When I go to the Scanner Utilities, I get this error:A scanner driver supporting th...
Hi, I recently got a new printer and I’m using my iPad to print, the problem is it prints every other page upside down. I’ve tried editing the pdf to have every other page to be upside down so it’ll print normally but even that doesn’t work for some ...
Hi I'm a NeewbieI have a Pixma IP8750 Printer, and I've notice a crackling sound coming from the mains connection when pluging in mains lead to back of printer. It's been doing it since purchased last August. Everything else on the printer works fine...
Hi,I'm trying to set up my Canon PIXMA MX925 printer & scanner on my new laptop running macOS Sonoma.Printing works fine so far, but the scanner isn't recognized and not showing up anywhere.This happens in both cases, wether I set it up via "Bonjour"...
How do I fix this issue or do I need to return it to the store?
My MG2550s printer (windows 11), prints the same page over and over. I reset the printer several times. Reinstall the program and drivers. No chance. What I can do now?
I have a TR4500 Series Printer It has worked fine for 2 years, But now there is a Yellow Light on, it is not blinking, the Power Button light is on, if pushed it does not turn off, there is no light on on the LCD , if you push any button nothing happ...
Does Canon produce an Inkjet printer + Scanner, like the MG7520, that support WPA3 network security Modes?
Ink does not dry on glossy11 paper . It's been two hours. Ideas ?245 XL CARTRIDGE
I have a TR 7020 printer for which I just bought new Canon ink cartridges. My printer uses the Cl-261 XL color and the TR-260 black. When I install them the printer says the color one is either empty or counterfeit. Is there a way to make it work? Th...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
