Desktop Inkjet Printers
Canon MG7500 scanning
I've downloaded current scanner driver for my Canon MG7500 but no matter what I do, it won't appear in 'Import' when I go to it through Photoshop. The scanner will work okay through IJ Scanner Utility, but I would rather it was there through Photosho...
allen-uk by Apprentice
  • 4952 Views
  • 0 replies
ImageRunner C2550 and sending scanned documents
I'm hoping someone can help me figure out what I may have missed in trying to setup the C2550 to work with either Gmail or Yahoo email. I've gone into the level 2 service mode settings page and tried specifiying port 465 and then also 587 as the SMTP...
My pixma printer skips lines/text only in black
My pixma printer skips lines/text.  Color prints fine.  Anything printed with PGBK (5) does not.  I have cleaned the printer head by removing the carriage that holds the cartridges and using a Q-tip.   That did not work.   It seems that many people h...
ChesterJ by Apprentice
  • 11839 Views
  • 3 replies
Canon MG6320 Printing Blank Pages
Printer has started to print blank pages.  Have replaced the two black cartridges, have performed deep cleanings.  The same thing happens via my laptop and my desktop.  I have the latest printer drivers.  My work around seems to work every time, but,...
MartyS by Apprentice
  • 5489 Views
Insufficient contrast
Scanning black-and-white drawings, using Pixma MG5420, into Image Capture on an intel iMac. Recipient says that more contrast is required - whiter whites and sharper blacks. Other than the contrast slider on Image Capture, is there any other techniqu...
MX492 shows "offline"
MX492 shows "offline"Restarted printer and repeated set-up a zillion times. Also Disabled the IPv6 per a suggestion I saw on community board. So frustrated! It worked and then just didn't. Printer is less than 1 month old.HELP!! ThanksJane
Pixma ip7260 prints blank apages
Without warning my ip7260 has started printing blank pages rather than what it is supposed to print. I have done the obvious maintenance without success.  After a number of attempts (but not straight away) i began receiving an error code 1403 message...
kafka by Contributor
  • 2842 Views
  • 0 replies
MP Navigator EX freezes - Canon F9000
I have Canon 9000F scanner. On my Macbook (Yosemite), after having scanned photos using the scanner driver, I then go back to the main window to save the photos. When I then gwant to go back to scan more photos again using the scanner driver, the pro...
rodrul by Apprentice
  • 2755 Views
  • 0 replies
