Error code 1300 on MG2520
slipnomo
How do you get rid of paper jam code (1300) when the jam has been cleared.
1 REPLY 1
Patrick
Hi slipnomo,
Please remove the jammed paper following the procedure below:
1. Turn off the machine, and unplug the power cord of the machine from the power supply.
2. Pull the paper out slowly, either from the rear tray or from the paper output slot, whichever is easier.
3. Hold the paper with your hands, then pull the paper out slowly not to tear it.
Please note: If you cannot pull the paper out, turn the machine off and turn it back on. The paper may be ejected automatically.
4. Retract the paper output tray, then open the cover. Important: Do not touch the clear film. If the paper or your hands touch the clear film and blot or scratch it, the machine can be damaged.
5. Make sure that the jammed paper is not under the FINE cartridge holder.
If the jammed paper is under the FINE cartridge holder, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper.
When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
6. Hold the jammed paper with your hands. If the paper is rolled up, pull it out.
7. Pull the paper slowly not to tear it, then pull the paper out.
8. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine.
Check the following and remove the piece of paper if it remains.
Does the piece of paper remain under the FINE cartridge holder?
Does the little piece of paper remain inside the machine?
Does the piece of paper remain in the right side or the left side space inside the machine?
9. Close the cover.
All print jobs in the queue are canceled. Reprint if necessary.
Please note: When reloading the paper, confirm that you are using the paper suited for printing and are loading it correctly. If the message about paper jam is displayed on the computer screen when you resume printing after removing all the jammed paper, a piece of paper may remain inside the machine. In this case, confirm that no piece of paper remains inside the machine.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Friends and Family
