Printer iP2700 error code 1300 but no paper in feed tray?
DennisDP
I have a Canon Printer iP2700 I am getting  error code 1300 which means paper jam, but there is no paper or fragments in the feed tray? Can I get around this?
Thanks
DerrickL
This is best info I could find to reset the code when there is no obvious paper  or pieces of  jammed in the printer:
Understanding Error Code 1300 on Pixma iP2700
Error code 1300 on the Canon Pixma iP2700 typically indicates a paper-related issue, even if there is no visible paper jam. Here are some common causes and solutions.
Possible Causes
  • Paper Misalignment: The paper may not be loaded correctly in the tray.
  • Incorrect Paper Size: The paper size set in the printer settings may not match the actual paper loaded.
  • Sensor Issues: The paper sensor might be dirty or malfunctioning.
  • Paper Type: Using the wrong type of paper can trigger this error.
Troubleshooting Steps
  1. Check Paper Loading:
    • Ensure the paper is loaded properly in the tray.
    • Adjust the paper guides to fit snugly against the paper.
  2. Verify Paper Size:
    • Confirm that the paper size in the printer settings matches the paper loaded.
  3. Inspect for Obstructions:
    • Look for any small pieces of paper or debris inside the printer that could affect the sensors.
  4. Clean the Sensors:
    • Gently clean the paper sensors with a soft, dry cloth to remove any dust or residue.
  5. Reset the Printer:
    • Turn off the printer, unplug it for a few minutes, then plug it back in and turn it on.
If the error persists after these steps, consider consulting the printer's manual or contacting Canon support for further assistan
6 REPLIES 6
DerrickL
Check inside the printer, paper fragments in the paper feed path?  Dirty rollers?
DennisDP
Thanks. No traces of paper - could it be hardware error?
DerrickL
Could be, did you clear a paper jam before the error, or did it show up on its own?
DennisDP
No previous paper jam. Haven't used the printer for a few months. I had to install a new driver first but got this error when I turned it on. I'm running a fairly old imac using Mac OS High Sierra.
DerrickL
Possible Causes
DennisDP
Thank you for your help. I'll try later.
