error 6001 in canon mx922
error 6001 in canon mx922 I follow the instructions,i turn the power off ,open the output tray and unplug,then plug it back on and still keeps getting the error message.pls. help what will I do?
Hello, Printer came with a seperate block that looks like it should insert in the printer for the ink cartridges.. BUT.. can't get it in there... Any body have experience with this printer... It is a PIXMA MG 7500 (refurbished)
I have a MX860 AIO which has always had wireless connection. I want to USB connect - cant find port
how do i get my laptop to recognise my pixma 2520 so i can print?
Had error B200Cleaned the printhead but now I have lost the Blue Wifi light.I have a permanent Amber colour light but no Blue light. Could this be a simple cure? Is there a separate fuse for the Blue light? Can I get a breakdown image to check this o...
MX860 was working fine. Now any attempt to print from any pc, either wirelessly or even using high-speed USB cable results in "printer not responding" error message. Any ideas? Thanks.
MG2440 pixma not power on My printer canon MG2440 not power on, press the power button power signal light is on (green light)Release the power button power signal light is off How can I fix it? I hope you can help me to fix my printer problem...Thank...
Hi, I have a problem with my printer. I will attach 2 pictures to see what it's suppos to print and what it's printing.I clean the printing head over and over again with hot water and nothing... Anyone can help me ? I don't know what to do. My cartig...
Printer prints top of page and the bottom but no content in between.
Ikeep getting code 1000. i feed paper but the printer wont accept. it sounds like its trying but there is a noise (slight grinding). Printer is rarely used and has 2 new ink cartridges. Please advise.
replacement arrived. getting a 1401 error. how do I install the ink? directions are very vague. insert and push down is not working. no ink lamp lights up. It's the weekend so cannon is closed. Please help!
I would appreciate any assistance regarding scanning to PC on my Canon MX922. Since upgrading to win 10, I have lost the ability to do this. Has anyone else had this problem? Is it fixable? Any help would be appreciated.
error message => "The type of print head is incorrect. install the correct print head."what should I do about this? mine is MG5470. thank you.
HOW DO I CLEAR A PAPER JAM IN MX459
I see that cannon wont support it in windows 10. It would scan automatically and open MP Navigator before but now says to set the pc to start the scan but Navigator says the scanner driver failed to start. Any help would be appreciated.
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
