01-10-2016 09:21 PM
Hello all, I did a clean install of Windows 10 Pro (64 bit) and I have a Pixma MX-870 which I use wirelessly. It and its software were working perfectly in Windows 8.1 Anyway, I downloaded the latest driver install and when I run it it begins and the installer detects the device and its IP address, etc., and when I it begins to install the drivers, it crashes when it gets to "Registering Fax Driver" each time. I get a "Canon IJ Driver installer has stopped working" message.
I've tried disabling anti-virus, the Windows firewall, turning off and on the router, running the installer as administrator, etc., but it doesn't get past that point. I can see in device manager that the printer driver installed and a WS version, and Microsoft Fax and Canon Fax, however I can't use MP Navigator as it says there is not Canon printer installed.
Any help?
01-12-2016 09:22 AM
well i found this and it worked for me:
"Hello.
If anyone is still having troubles with this issue, please try the following:
1. From the Start menu, click Settings, Devices, Printers & Scanners.
2. Towards the bottom of the Printers & Scanners area, turn off Let Windows manage my default printer.
3. Once this has been done, reinstall the drivers again.
You may also have to delete any extra icons of the printer in the Printers & Scanners menu.
01-12-2016 08:03 AM
I have the same issue with windows 10 and MX925, crashes at registring the fax drivers. last time i found a workaround but i forgot how...
01-12-2016 09:22 AM
"Hello.
