03-08-2014 11:15 AM
I have a Pixma MP620. I bought all new cartriges for it a couple of months ago, have printed only B&W word documents, and far fewer than 100 documents, yet my black is empty, and the magenta and cyan are dangerously low. The yellow is at half. I figure I've paid almost $1.00 per B&W page.
WTF?
02-26-2021 04:36 PM
Y'all sold me on a toner cartridge machine to prevent this bull**bleep** maintenance soooooo where is the lie?
05-20-2021 02:42 PM
05-20-2021 03:00 PM
The answer to everyone in this threads question: Canon doesn't give a **bleep** about you and only wants to make a profit off of ink and printers.
Why does your printer say your full/new cartridges are only 50% full? Because canon wants you to buy more!
Why does the printer say the ink is out but it isn't? Canon wants to deceive you into buying more ink before you need to!
Why does your printer suck up ink even when you don't use it and even though you bought the toner machine they told would reduce this? Becuase they want to trick you and force you to buy more ink so they upsold you into a product that costs more so that you are now pot-committed to the continued purchase of their **bleep** products!
The answer is... they don't give a **bleep** and just want to push ink sales up. This is guaranteed the #1 key performance indicator for canon.
05-20-2021 06:26 PM
07-14-2021 12:43 PM
I as well loose ink so quickly. Bought all new ink cartridges a week ago, nearly 100.00 and 4:are showing low even though I've printed mostly black documents with very little color at all. This can not be right. WTF so frustrated
07-14-2021 12:46 PM
03-28-2022 05:30 PM
I'm stunned and made a huge error by buying a new printer before investigating the cost per year for the cartridges. By the time I set it up since it required me to repeat various testing and cleaning on the unit several times, I could see the color cartridge was close to half-empty and the black went down nearly 25%.
05-16-2022 09:22 AM
I have the same issue with my TS7451 printer.
Bought it 9 months ago and printed < 100 pages, i only turn on it when i needed to print or scan, which only several times a month, and i turn it off after i finished.
Today when i try to print a black and white copy of document, it printed the document with some broken lines or very light black color which means that it run out of the ink.
I then use another HP printer (OfficeJet Pro 8020) which i put it aside and not touching it for 9 months, although this printer also claiming that the ink is going to run out, but at least it printed out with some solid black lines.
I am so disappointed for Canon that the ink are running out based on time but not the usage.
05-16-2022 12:34 PM
The only thing I can suggest is to go into Printer "Properties" then "preferences" then under "print quality" set it to the Draft setting. It uses less ink. Your still not going to be happy though but it helps some
10-02-2023 04:18 PM
This does not help at all! The printer was a great price, but the printer is trash if you have to pay $1 a page!
I would definitely not recommend a Canon Pixel to anyone!
