Apple users Pixma G1220 utility access. Was this ever working? wildly expensive printer dead
garyrwow
If you try to operate this printer on and apple computer it can’t run maintanence.  I just found this out in the most painful way.  Tech support scambled to find a link for a patch or an app for the apple users maintenance… and failed.  (I was told to find a new computer)  wow
2 REPLIES 2
DerrickL
Performing Maintenance on Canon PIXMA G1220 from the printer control panel (alternative for Mac Users)
Accessing Maintenance Functions
To perform maintenance on your Canon PIXMA G1220 directly from the printer control panel, follow these steps:
  1. Power On the Printer: Ensure the printer is turned on and ready.
  2. Navigate to Maintenance Menu:
    • Press the Home button on the control panel.
    • Use the arrow keys to scroll through the options until you find the Maintenance menu.
Maintenance Options Available
The following maintenance functions can typically be accessed:
Function Description
Cleaning Print Heads Cleans the print heads to prevent clogs.
Align Print Heads Aligns the print heads for optimal print quality.
Nozzle Check Prints a test pattern to check for clogged nozzles.
Cleaning Paper Feed Rollers Cleans the rollers to ensure proper paper feeding.
Steps for Specific Maintenance Tasks
  1. Select Cleaning from the Maintenance menu.
  2. Follow the on-screen prompts to initiate the cleaning process.
Aligning Print Heads
  1. Choose Align Print Heads from the Maintenance menu.
  2. Follow the instructions displayed to complete the alignment.
Performing a Nozzle Check
  1. Select Nozzle Check from the Maintenance menu.
  2. Print the test pattern and check for any missing lines.
Conclusion
Regular maintenance helps keep your Canon PIXMA G1220 functioning well. Use the control panel to access these features easily and ensure high-quality prints.
OK i can run THAT maintenance but not the flow purge function (I have pressed all the buttons) Canon is letting me down by skimping on the software I need to do this maintenance.  But only for the apple user.  Thank you.  That doesn’t resolve my issure sorry
