Unreadable Print Head Pattern
HopefulWaiter
I am unable to get a readable (it's very faint and not complete) print head pattern sheet so that I am able to manually realign the printer head.  Any suggestions?
2 REPLIES 2
Moderator
Moderator
Hi, HopefulWaiter!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
jrhoffman75
Sounds like you need to run a cleaning cycle and repeat as necessary until you get a good nozzle check pattern. Then repeat the alignment process.
