07-12-2013 02:02 PM
Am i the only person that received a " Support Code 1413" when changing ink?
07-14-2013 04:49 PM
Hi!
The community is eager to assist! To ensure the most accurate information is provided, we’ll need to know the model of the printer you are using. We look forward to hearing back from you!
07-14-2013 06:41 PM
07-15-2013 01:45 AM
Hi rgabby,
To try and resolve the issue, please ensure all tape has been removed from the ink tank, then reseat the ink tank in the printer. Once this has been done, if you still experience the same issue, we recommend replacing the ink tank with a Canon genuine ink tank. Canon supplies and accessories for the PIXMA MG5422 can be purchased online at the Canon eStore here:
This didn't answer your question or issue? Find more help at Contact Us .
07-15-2013 12:54 PM
07-16-2013 01:48 PM
01-09-2019 05:55 PM
01-09-2019 05:59 PM
Hi OCStudent!
Thanks for posting in the Canon Forums!
The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback.
If you are in the United States and this is an urgent support need, please CLICK HERE to reach our friendly technical support team.
If you live outside the United States, please click here and select your country or region for your support needs.
We hope this helps!
07-16-2013 10:14 PM
Hi rgabby,
Since Canon does not provide product specifications to third parties, testing Canon inks with the printer will help make sure that this error is not a hardware problem with the printer. If you still experience difficulty with the printer, please use the Contact Us link below for further assistance.
If this is a time-sensitive matter, additional support options are available at Contact Us .
