07-01-2016 06:04 PM
I have never had any issues with this printer until now. It wont let me do anything and says I need to Install the Correct Print Head. It was bought with all origional pieces? What do I need to do?
I seen someone else post about this issue and I followed there guidlines but they had a slightly different printer and didnt have the same interior as mine.
I restarted the printer, took out all the ink cartridges as what was said to do and looked for the grey lever they were talking about but I dont think mine has one?
Any way the printer is still on support code 1403 so someone please help!
Thanks
05-20-2020 02:34 PM
05-20-2020 05:10 PM
I bought a really cheap Brother and it has worked fine (and I can get cheap generic ink). The absolute riculousness of the canon error is sad. Let's make a multi-fuction printer that won't do any functions if there is a printhead error. Why not scan? WHy not fax? Why not be able to be fixed? Oh, you can try to fix it but there is no gurantee of the fix working, so more money down the drain.
07-20-2020 03:44 PM
07-20-2020 03:47 PM
08-24-2020 05:19 PM
Same error, did all the recommended fixes. Looks like I will be buying a new non-canon printer......
08-31-2020 01:51 PM
08-31-2020 01:57 PM
Yes, it is garbage. The only repair suggestion from Canon is to buy a new print head. Which is fine, but most people that buy a new print head still get the same error. Then Canon jsut shrugs their shoulders and may offer you a 5% discount on a printer than you can buy for a 50% discount from many other places.
It would be like taking your car to the mechanic because you have warning light on and they say, you should buy some parts and see if that fixes it.
Don't throw money away on trying to fix a problem that likely can't be fixed.
10-14-2020 09:40 PM
So, I just got a secondhand PIXMA MG7520 from facebook, it was 20 bucks and working (the only images was it off and it on with the inktray up, ironic), so I get it home, hook it up and it shows the fable “printerhead invalid” and in my case I couldnt even get to the menu so literally stuck on the error, I tried resetting it, I washed the head off, cleaned the contacts with alcohol, cleaned the contact surface inside the printer, tried resetting the cartridges and nothing. after punching it a few times I decided to take it apart because since it doesn’t “work” I cant make it worse, I took the leftside panel off and saw the three ribbon cables going to the head connector and I just started unhooking them, and turning it on to see what happened, until I got left with the combination of leaving the center ribbon cable off and the two corner ones on and to my surpise.. it finally got to the **bleep** home screen, I tested scanning something and printing it, it worked, tested printing a calibration page, it worked, connected it to my wifi and sent a test page from the computer.. it also worked. So I have no clue what that middle ribbon cable does but for some reason it worked for me, and as soon as I plug it back in, it throws the error. (its also reading toner levels) So I’m not saying “do this!” and I dont know the longterm effects, but it worked for me, if you have nothing to lose.. maybe give it a go. In the future I might take it apart all the way to the head assembly and see why that particular cable is wonky.
10-17-2020 12:34 PM
@angrycustomer wrote:Cannon support delete my messages here about my method to fight with 1403
insted help us
Try to do next steps:
1) Remove all cartridges and trays
2) Diconect power cord
3) Connect power cord and turn printer on
4) When printer turned on - probably you will get messages about cartridges.
5) Install them, put tray with paper back
6) Push Menu button, than go to Maintenance -> Auto Head Alignment
7) It will take 5-10 min and you Done!
For my printer I get 1403 every 500-1000 pages.
Thankyou 'angrycustomer', what a brilliant fix! Had all but given up on my MG7550 with this error code, having tried several 'fixes'. This one really did the trick and so easy. Very many thanks, youve saved me a fair wedge of cash. Really pleased, just got to clear the backlog of printing and scanning now!
10-18-2020 02:21 PM
