Resetting the Fax Memory on MX310
Franklin
I wondered if there is a way to clear the fax transmission log on this all-in-one printer.  Alternatively, is there a way to reset the printer to factory settings (and effectively erase all memory)?
Thank you for your input.
3 REPLIES 3
Patrick
Hi Franklin,
To reset your PIXMA MX310, please follow these steps:
1. Press the MENU button repeatedly until Device Settings appears.
2. Use the [-] or [+] button to select Restore Default and press OK.
Dear Patrick,
Thank you for your response.  I restored the default as you suggested but the memory of the fax transmission log is still retained.  Are there other methods I can use?  I appreciate your and the community's help.
Please click HERE for the steps to delete any faxes that are stored in the printer's fax memory.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
Friends and Family
