05-30-2021 02:56 PM
The lower paper tray on my MX922 gets firmly stuck if it's empty. I have to wrench it forcefully half a dozen times to get it back out to load more paper. Of course, the obvious quick fix is to never let it get too low on paper, but I often print on special sizes, usually one piece at a time or it will try to feed multiple pieces at once. I've cleaned the edges of the paper tray and the places where it slides in. I've checked that spring thing underneath, no problems. I've turned the whole printer upsidedown to make sure there wasn't something jamming it up, I've cleaned the rollers, even though that didn't seem like it would make any difference, and it didn't. I'm at my wits end. Anybody else have this problem, and did you find a reason or solution? Thanks very much!
01-02-2022 09:49 PM
I found that you can release the tray as follows, using a piece of corrugated cardboard about 6 inches wide and long enough to reach to the back of the paper tray. The long dimension is parallel to the ribs of the cardboard. The procedure is as follows: (1) Remove the top paper tray. (2) Insert the cardboard into the gap where the top tray had been. (3) Slide the cardboard back until it pushes up on the rollers that are at the back of the tray: this pushes the obstruction out of the way of the lower tray. (4) The tray should now slide out easily.
06-09-2021 03:23 PM
Hi ShadowWings,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
09-19-2021 01:18 PM
I had the same problem . With experimentation I've found the tray was binding a little. To make it a little easier I set the printer on 2x4s (flat) just clearing the tray on each side. It worked for me.Allows you to pull down easier with thumb on tray.Hope it works for you.
01-02-2022 09:49 PM
01-03-2022 04:57 PM
Outstanding.I've been doing a previous post by lifting bottom tray a little while and pulling to left. .It works but a little of a hassle.
But I just did your trick. Happen to have scrap card board . And it works great!! How did you com across this idea?
Thanks again.
02-04-2022 02:46 PM
I ran into this issue also and it made no sense as it had always opened and closed fine. I removed the top photo tray. I slid the paper tray in as far as it would go. I could see that a piece was not able to slide into a slot in the way back. I picked up the printer and found that my cord was under the machine and preventing the tray from sliding into the slot. After moving the cord to behind the printer the issue was solved. Hope this helps you.
03-11-2022 12:37 PM
Hello Patrick,
Where Can I buy Canon Part# QL2-6451-000 for MX922? I called 866-481-2569 and they don't have the part, and they gave me the part#, This is the lower paper tray feeder that's broken, and rollers don't spin because inside the arm where the gears a piece of plastic broken on the shaft section to the feeding rollers are and won't feed the paper. I also spoken to Canon customer service without any help.
03-14-2022 09:03 AM
That worked! In the meantime, before you posted this excellent workaround, I figured out another workaround. I used crafting foam to build a 1/2 inch base, taped all around with packing tape, which stays in the tray all the time. With the base in there, it no longer jams. I can still put plenty of paper in, but when it runs out, there's no problem getting the tray open. I made a smaller size as well for envelopes and odd sized papers that I use. As long as there's something in there 1/2 inch high, the tray pulls out. Thanks for this trick! I have had a few times when I forgot to put the base back in when I took it out for a different size and then had to wrestle the tray again.
03-21-2022 02:13 PM
Hi kjrachuy,
The Parts Department may be reached by calling 1-800-828-4040, seven days a week (excluding holidays), 8:00 a.m. to Midnight ET. They can provide you with availability and cost.
03-22-2022 04:50 PM
I tried that didn't work. Best thing is so far is lift up tray and pull to the left while pulling tray out.Works with out all the other tricks mentioned.
