03-06-2022 03:27 PM
I wondered if there is a way to clear the fax transmission log on this all-in-one printer. Alternatively, is there a way to reset the printer to factory settings (and effectively erase all memory)?
Thank you for your input.
03-16-2022 03:03 PM
Hi Franklin,
To reset your PIXMA MX310, please follow these steps:
1. Press the MENU button repeatedly until Device Settings appears.
2. Use the [-] or [+] button to select Restore Default and press OK.
03-20-2022 05:44 PM
Dear Patrick,
Thank you for your response. I restored the default as you suggested but the memory of the fax transmission log is still retained. Are there other methods I can use? I appreciate your and the community's help.
03-22-2022 12:47 PM
Please click HERE for the steps to delete any faxes that are stored in the printer's fax memory.
