07-11-2013 01:36 PM
Whenever I click on the Quick Menu program for the subject product, I get the following error message:
Canon Quick Menu has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I have uninstalled and reinstalled the driver and Quick Menu software several times, from both the disc provided and on-line downloads.
I have turned off my anti-virus/firewall program and also told the security program that the Canon program is a trusted application.
I am able to print/scan/copy, but not from the Quick Menu, which is more convenient.
Please help.
02-28-2014 01:37 PM
Hello jerrystarrus,
Check out the link below for step-by-step directions, just select "Mac" under "Initial Setup:"
If you are running into any difficulty in the procedure, it would be best to get in touch with our technical support team at http://bit.ly/Phone_Support for further assistance.
Thanks!
10-21-2014 10:30 AM
Well that was super easy. Thanks so much for writing in crayon. I usually have such a hard time following instructions.
I have a PIXMA MG7120. So the only difference for me was that I needed to leave the SG20 folder and the wiatwain.ds file in there. It was my old Lexmark printer data in there that was causing the problem.
11-13-2014 10:12 AM
Thank you ! Thank you ! Thank you !
I can now scan !
08-04-2015 03:49 PM
I need help on 2 items.
1. My Canon Quick Menu will not load
2. I cannot get the scan utility to work. I have windows 7. I went to c:\windows\twain_32. In that folder I have SG20 and wiatwain_ds.
My scanner will work in paint, because that is windows software. My printer works fine.
08-04-2015 04:35 PM
I can't get my scanner to go to anything but PDF, and I hate PDF's
08-06-2015 09:26 AM
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issues. Please contact our support group using the "Contact Us" link below for additional assistance.
08-06-2015 10:46 PM
12-31-2015 06:01 AM
Hello i have a problem with the installation of PIXMA MG 2950.
I use windows 10.
I follow the steps normally for the installation. When i reach the point of printing alligment the printer is not responting and i get the message
I can not print at all from my pc.
Please help
01-30-2017 09:30 AM
tyty6 so much for me registering
02-13-2017 01:37 AM
Karl1
I tried your solution and there was a file foe a Dell printer which I moved to the desk top and then rebooted but I still can't scan - I've just noticed I have a MG4250!
