12-25-2020 10:43 PM
My printer is about 4 years old. I replaced one tank and suddenly it can't recognize any. These are the same Canon ink tanks I always use. I took the tanks out and examined the area for foreign bodies and found none. I turned it off and back on. Is this printer kaput?
12-26-2020 11:50 AM
OK I figured it out. I ordered XL cartridges. They are number 281. Wrong.
12-26-2020 10:48 AM
Please see these articles for proper ink replacement.
Canon Knowledge Base - Replacing Ink Tanks - TS6020
Canon Knowledge Base - Checking the Ink Status with the Ink Lamps - TS6020
12-26-2020 11:22 AM
Thanks. Will do.
12-26-2020 11:43 AM
I believe I have followed all of these instructions carefully. I did reinstall each ink tank just now. They lit up briefly as the carriage began to move, but they are all off now. The printer was fine until I put in a new blue cartridge on Thursday. It is a Canon but maybe there is something wrong with it.
12-26-2020 11:50 AM
12-27-2020 08:09 AM
Thats a bummer. Hope you can get them swapped out somehow.
