Pixma TS 8220 Encoder strip clean/replace
flj0303
I have a PIXMA TS 8220 printer and am generally happy. Just in the last two days it will not print without skipping lines/ and leaving white gaps between lines, every 1/2 inch or so. Seems like this has something to with the encoder strip, which I can see on one end but not all the way across to clean it. I do not see how you would replace it, and when you open the printer top, it is covered by a black plastic cover which makes it inaccessible. I do not see how to replace the encoder strip anywhere for this model, nor am I sure that is the problem anyway. I have tried to print from multiple devices so I know the problem is in the printer, not the software. I did have a paper jam recently so, based on what I have seen online, it seems likely the strip may have grease on it. I did clean the part I could see with a alcohol and a swab, but I want to be able to clean the entire length. Any suggestions.?
2 REPLIES 2
flj0303
right side showing stripright side showing stripmiddlemiddleleft side showing stripleft side showing strip
Based on the steps you have taken already and the issue remains, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
