11-04-2023 05:36 PM - last edited on 11-06-2023 11:19 PM by Kristoff
Hi, need help getting my new Dell XPS to connect to my MX922. I've tried DL'ing drivers but nothing has worked. Any assistance is appreciated.
Thanks!
Using Windows 11
11-15-2023 01:39 PM
Hi turtur76! Thanks for posting in the Canon Community Forum. I see that you are unable to install your MX922 to a Windows 11 computer.
You mention that you are downloading the recommended driver from the Canon website. You also say that the computer is recognizing the printer, but it won’t connect wirelessly to print. We can help you with this issue, but we will need more details.
We need to pinpoint where the problem is occurring and what error messages are being displayed so we can provide the steps you need to install the printer. Here are a few questions that we would appreciate answers to. Please provide as many details as you can and feel free to provide information that may help us figure out what is going wrong.
Here are a few suggestions you can try before replying to us.
If you have not connected the printer to your Wi-Fi, you can disconnect the USB cable and perform the Standard Setup option available through the printer’s menu. The following web article will help with that:
https://support.usa.canon.com/kb/index?page=content&id=ART164598
If the printer is already connected to your network, please turn the printer off and restart your router. To restart the router, you can disconnect the power cable and reconnect it. Then, wait three minutes for the router to finish restarting before you turn the printer back on. If you have one router and several extenders, please restart all of them.
Finally, you can try disabling both the Wireless LAN DRX setting and the IPv6 Setting. Here are the steps you can follow:
When you have returned to the IPv6 settings menu, you can press the COPY button to exit to the main menu.
If none of these articles help and you are still unable to print, please write back with answers to the questions I listed earlier. Please be descriptive and feel free to provide additional information that isn’t asked for in the questions.
I hope this information helps. Thanks again.
11-04-2023 10:29 PM - edited 11-04-2023 10:30 PM
So many questions......
What operating system? What is your installation procedure? Are you following the instructions exactly? What exactly is failing to happen? What driver are you using?
11-05-2023 07:16 AM
Hey, thanks for responding. All good questions. Computer is running Windows 11. I’m going to Canon’s website and downloading the suggested driver. I’m following all of the instructions Canon provides and the computer is recognizing the printer but it won’t connect wirelessly to print.
11-15-2023 01:39 PM
11-15-2023 05:22 PM
Thank you for your help; it's appreciated. I got it working.
