05-28-2022 05:27 PM
Canon Pixma MX490 powers on and goes through initialization, then powers back off. Keeps repeating the process as long as it's plugged in. Buttons are non-responsive.
06-03-2022 05:52 PM - last edited on 06-07-2022 02:03 PM by Danny
Your satisfaction is important to us, and we apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
06-05-2022 01:14 PM
This works. One additional note. If you have an app on your phone for your home network, you can simply disconnect the printer from there as opposed to shutting down your whole wifi system.
06-05-2022 05:28 PM
This is all fine and dandy but what effect will this have for those who went with the domain name service work around that was suggested on June second 2022?
06-05-2022 07:08 PM
I did the DNS work around but not the update. So far my printer is working fine on wifi.
06-05-2022 07:16 PM
Ok, but it says to connect a USB to my computer to download the new firmware. How do I download the firmware if I do not have a computer and my cell phone and tablet as my only devices ?
06-05-2022 07:27 PM
Unfortunately, I cannot answer that. I don't use a tablet. Why not just do the DNS workaround so you can operate your printer on wifi again until you can access a computer? Unless someone else here can help you with downloading the firmware to your printer via a tablet. Sorry..
06-05-2022 08:42 PM
graumli, i do not have a laptop, however I am able to borrow one. I downloaded the fix, but the printer utility is not coming up for me to apply. any ideas on how to proceed?
06-05-2022 08:46 PM
What did you download the fix to, your phone?
06-05-2022 08:54 PM
I borrowed a laptop from a good friend. But I am not getting the printer utility to apply patch
06-05-2022 08:59 PM
Do the work around of changing your printer's DNS number. Disconnect the printer from wifi (disable your wifi router), this will allow your printer to stay on. Use the printer menu to change the DNS number by any digit. Then you'll be able to reconnect to wifi and use your printer as usual.
06-05-2022 07:34 PM
If you do the DNS workaround so you can reconnect the printer to your wifi, you can follow these instructions I found to download the firmware
https://support.usa.canon.com/kb/index?page=content&id=ART162662
