05-28-2022 05:27 PM
Canon Pixma MX490 powers on and goes through initialization, then powers back off. Keeps repeating the process as long as it's plugged in. Buttons are non-responsive.
06-02-2022 11:38 AM
I don't know about anyone else, but my MX490 will not stop reboot/cycling. I unplugged cable to router and I am unable to get to the menu set up devices tools screen to disconnect from the WiFi. It just keeps cycling
06-02-2022 11:40 AM
Sorry, you have to unplug the printer and shut off your modem/router. Then plug the unit back in.That should work.
06-02-2022 11:41 AM
If not, do a printer reset then try again.
06-02-2022 11:44 AM
This works. Thanks. I also adjusted the IP address by 1 number.
06-02-2022 11:46 AM
Is there any way to fix this?!
06-02-2022 11:52 AM
Yesterday, I changed the IP address of my printer to a made up one and it prints from both my laptop (wifi) and desktop. If you need a valid IP for another reason, see below:
This problem that you are experiencing is because of DNS. I solved my problem by turning off he printer, then the router/modem.. The printer will turn on normally. Then go to Setup menu > Web service setup > DNS server setup > Manual setup. Configure an IP from your internal network that is not in use or another IP that is not a DNS server, as the printer will not be able to make queries. Once configured, press OK. Select the 'No' option and press OK. Wait a few moments to complete the configuration.
06-02-2022 11:54 AM
Never fails. I don't use my MB2320 very often. Always something. I bet I have only printed maybe 150 sheets. Ink dries out way too expensive. Cost more than the printer. Plus this thing is a monster on my desk.
06-02-2022 12:01 PM
unfortunately that didn't work either. It wont stop cycling and I cant get to any device, set up, or menu screen. This just may be above my pay grade and I have to call my IT guy.
thank you for the advice.
06-02-2022 12:45 PM
If you do call your IT guy be sure to show him this thread, I don’t expect him (or her) to know how to solve it without seeing the workaround presented here (even Canon support don’t know how to overcome the issue yet), but he will be able to follow the instructions.
06-02-2022 12:59 PM
So what printer should I purchase since Canon doesn't seem to have a fix for this?
