06-29-2017 12:39 AM
I load the paper in the rear tray and print; the printer starts the setup to print, where it draws in the paper by about two inches, moves the printer head in the correct location and gets ready to print but then says please load paper. I did a deep cleaning as well as a roller cleaning. The center roller seems to be in contact with the paper and when it draws in the paper it is slightly out of alignment. It draws in the right side a little more than the left. If I push the paper guide rails to be snug or leave it a little loose it doesn't seem to make a difference and before and after this problem occured I updated the printer drivers, so I am not sure why the printer doesn't recognize the paper in the rear tray.
Any help is greatly appreciated.
Tomloc
06-29-2017 01:05 PM
Hello.
Turn the printer off and unplug the power from the unit. Then check to see if any obstructions happened to fall in the sheet feeder.
If the issue persists, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
06-30-2017 05:45 PM
Thanks. Unfortunately there doesn't appear to be any remenants of paper in any of the back tray paper feed rollers or any of the other rollers underneath the glass. I will have to contact the support group for further analysis. I appreciate the quick reply.
Tom
