Pixma MG5320 has stopped working - Not getting any power / Dead
jgvisser
While printing docs for school this evening, the printer (PIXMA MG 5320) just stopped working - like it had been powered off - and won't come back on. It printed several things and when it went to do the next doc it had no power. I have it attached to my Lenovo T400 laptop via a printer cable and also use it via Bluetooth. It has worked great for some time and now just is dead.
I've tried unplugging for 5 - 10 minutes and plugging it back in with no luck. Checked that the outlet is working and it is. Tried a different outlet and still nothing.
I'm using Windows XP to send docs and photos. I've been very pleased, and have no idea what happened.
16 REPLIES 16
mimidee74
Did you ever find a solution to this problem?  I have the same exact problem.  No power...nothing.
Ramona
Hi jgvisser and mimidee74,
In addition to the steps you have already tried, please ensure that the power cord is plugged securely into the printer, as the cord may have slightly come loose and and prevented full power to be received by the printer.  You will also want to ensure that the printer is plugged directly into a wall outlet instead of going through a surge protector that is plugged into a wall outlet, as sometimes one port on the surge protector may not work while others do.
If the printer still does not power on, it will require servicing.  Please Contact Us for your servicing options.
meringuehead
Did you ever get this printer serviced per Ramona's recommendations? What happened?
mcmarturano
I just encountered the same problem. Printer is totally dead. I plugged it directly into the wall and no change. Sounds like a blown board maybe? Looks like the warranty is only one year... too bad this is a relatively expensive printer to have shipped with faulty boards...
why is it all of these printers have shut down, mine has also, it just stopped working, I will never buy another one again if you can't make good for it and I will tell my friends about this and how many printers just brake down.
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Where is the contact us link I'm having the same issue?
Hi Seahawk425!
If you click on the words 'Contact Us' in the post above, you will be taken to the page where you can reach out to our support team. Here is a shortcut as well:
https://www.usa.canon.com/internet/portal/us/home/contactus
We hope you find this useful!
Arkonis
Just experienced the same problems. Has any solution been found?
