02-05-2025 09:29 PM
My RS40 had been working fine. When the Windows 11 came out recently, it stopped but I found the answer with that Citrix setting and it worked fine once more. THEN, last night I loaded an update for the RS40. Now whenever I try to scan something from within the program I get the error above.
I am running Windows 11 version 24h2 on a Dell 64bit system. I have uninstalled and reinstalled and restarted but no luck yet. Thoughts? THANKS!
02-06-2025 03:56 PM
Okay, I got it figured out. After multiple uninstalls and reinstalls, and running the configuration tool several times, I did a couple of things (my change management wasn't good so no way to tell what made the difference. I first went through steps to find what the name of a driver for the RS40 was. Then got THAT registered. THEN, I worked on determining why the scanner wasn't visible in the select scanner screen. Finally determined I needed a new TWAIN driver. I had ASSUMED that would be in the larger RS40 version 4 service pack, but apparently it wasn't. I downloaded JUST that driver and registered it. THEN I downloaded the latest Windows 11 service pack. Rebooted and was able to select the scanner. It works now.
02-06-2025 01:41 PM
To add some context, I FINALLY got the RS40 to be 'running properly' in Device manager, but still get this message above. OF NOTE...when I open up the 'Select Scanner' screen no scanners are listed. Help please!
02-06-2025 01:43 PM
Thanks for joining the conversation, combatwx!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
02-06-2025 03:56 PM
