11-08-2018 05:39 PM
Hi there.
Anyone else having trouble getting the CANON PIXMA 4210 scanner to work with macOS Mojave v. 10.14.1 on wireless. Able to print, but the scanner isn't recognized.
Tried CANON Tech Support who weren't very helpful. Said Canon hasn’t delivered a driver that’s compatible with OSX Mojave yet.
Very disappointing as this is a new printer.
11-09-2018 08:36 PM - edited 11-09-2018 08:39 PM
Spent an hour on the phone with Canon Tech Support today. They tried a bunch of different things to try to get the scanner to work. Finally gave up and confirmed it must be a driver issue; they said they would escalate and get back to me.
Disappointing as the G4210 is advertised as fully compatible with macOS including Mojave v10.14
https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/Mac-OSX-Compatibility
11-16-2018 09:43 AM - edited 11-16-2018 03:09 PM
@Sailormannn wrote:Spent an hour on the phone with Canon Tech Support today. They tried a bunch of different things to try to get the scanner to work. Finally gave up and confirmed it must be a driver issue; they said they would escalate and get back to me.
Interesting. It's been a week since I escalated to Canon Tech Support. No changes to my macOS or Canon Firmware, and no further contact with Canon Support. Today, I tried scanning for the first time since last week and guess what, it works. Used the Canon IJ Scan Utility Light to perform a couple of scans. It found the scanner on the network and worked.
No idea why it now works; since Canon Tech couldn't get it to work last week and no changes to my system. One thing though. I tried a scan using the Mac Image Capture and it still gives me a communication error.
Glad I'm able to scan but not sure if Canon had anything to do with it.
11-21-2018 01:57 PM
Hello.
Make sure that the IJ Scan Utility LIte program is installed. Visit the following link to access the download:
PIXMA G4210 Drivers & Downloads
Once there, go to the "Software" section to download the program. The program can be found in the Canon Utilities folder in Applications.
11-21-2018 02:17 PM - edited 11-21-2018 02:18 PM
@Michael wrote:Hello.
_______________________________________
Thanks ... I am using the IJ Scan Utility Lite program. I think I figured out what might be the issue though.
I am using a Hitron Coda-4582U gigibit modem/router. It has 2 networks one that is 2.4 and another that is faster and identified by the same network name but with the extension "5G". My macs are typically using the 5G network and are both able to print on the G4210. If I try to scan on this network, however I get a communications error. This is usng the IJ Scan program. If I switch to the 2.4 slower network, it seems to work and I am able to scan, albeit at slower speeds than I'm able to print.
I think this could be resolved if I can figure out if the G4210 is able to connect to my 5G network and if the scanning function is compatible.
