10-31-2013 12:19 PM
Paper jam message recd./ No paper fed through. Checked everything, nothing found. Cannot delete the error message, and I am not able to print anything. This is effecting my business.
11-08-2013 03:37 PM
Fixed problem myself. Using a piece of cardstock that was laminated, fed through printer rollers and discovered a small piece of paper that was lodged in there. Problem solved and I am able to print again. : - )
11-08-2013 11:44 AM
Hi skybird,
There is on last step we can try. Disconnect the power to the printer and then press the ON button 5 times. Wait 10 minutes and then reconnect the power. If the error returns after powering on the printer, then it is detecting an internal malfunction and will need to be service. Please contact us to discuss your service options.
11-08-2013 03:37 PM
