01-21-2025
09:16 PM
10:01 AM
James_C
I recently upgraded to Windows 11 and dumped my old Brother printer, but I'm beginning to wonder if that was a wise decision. I now have the Canon TS9520 but it keeps defaulting to rear paper tray. It reverts even if I tell the computer to default to the to the cassette. The only way I have found to use the cassette is to tell Windows 11 to always go to print preview and then select the cassette during print preview. I am using Windows 11, with MS Visio 10 and find this really strange. It doesn't happen with my HP4650 and it didn't happen with the Brother printer. I suspect an issue with the driver and Windows 11, but I have no way to test that theory. Any Ideas?
01-23-2025 11:02 AM - edited 01-23-2025 11:02 AM
Hi Bobclark1,
Please try setting the rear feed to 4" x 6", so when you print from your computer on letter sized paper, the printer will default to the cassette.
To do this, please follow these steps:
1. Turn you PIXMA TS9520 on.
2. Tap the gear icon at the bottom of your printer's display.
3. Tap Feed settings.
4. Tap Rear tray paper settings.
5. Tap the Change button.
6. Select KG/4"x6"(10x15) from the list.
7. Choose Pro Platinum, or any type of paper.
8. Tap Yes.
9. Tap the Home icon in the upper left corner.
Once set, please attempt to print.
07-09-2025 08:03 PM
I tried that. It just keeps trying to use the rear feed. Is it Visio that is the issue or perhaps Windows 11
07-10-2025 09:33 AM
Hi Bobclark1,
Please change the printer driver's default setting to the cassette:
1. On your computer, please press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window that appears, please type CONTROL and click OK.
3. Click on View devices and printers.
4. Click on Printers & scanners.
5. Click on the Canon TS9500 series from the list.
6. Click on Printer preferences.
7. On the Quick Setup tab, set the Media Type to Plain Paper, the Printer Paper Size to Letter.
8. Set the Paper Source to Rear Tray.
9. Click Apply and then OK.
01-01-2026 02:18 PM
No this did not work
01-01-2026 03:23 PM - edited 01-01-2026 03:26 PM
You asked about Visio. Bypass it completely and see which feed is used. Try this test page. It should let you choose front or back. Make sure you choose your printer as the destination.
02-23-2026 10:00 AM
That doesn't work. Even when default is set to Cassette, and default is set to Cassette, and Rear Tray is set to 4x6, it won't print 8.5 x 11 from the cassette if you choose photo.
02-23-2026 01:41 PM - edited 02-23-2026 01:46 PM
This thread is over a year old and has three users posting to it. To receive support and assistance please start a new topic. This is important for the following reasons:
*Posts can become splintered when multiple users with different hardware and environments are trying to receive help on the same thread.
*It's not possible for you to mark a post as resolved unless it is your own.
*It's difficult for those of us trying to help to stay on topic and provide accurate/correct solutions.
*It makes it difficult for others who are searching for solutions.
*It's important that each user start their own thread so their problem or issue receives the visibility it deserves.
Thank you in advance
How to start a new topic or thread:
Please give your topic a meaningful title. Please choose the correct forum category. Camera, Printer, Accessory, etc.
Please identify your Canon product by model
Please provide a description of your issue, your operating system, build and version, and any other relevant information that might help us better understand your issue. Please add any troubleshooting steps or error messages you may have observed or tried.
New topic:
Thank You 😉
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
