How to disable fax machine on the PIXMA TR8622a
CindyV1
I am hoping there is a way to disable the fax on my TR8622a. It interferes with most of my phone calls by disconnecting and putting out that fax noise.
4 REPLIES 4
Have you set the fax receive mode settings to telephone priority?
Canon : Inkjet Manuals : TR8600 series : Setting Receive Mode https://share.google/A9hS3Y16Uv0twbJpK
Stephen
Moderator
Moderator
To disable the fax function on your Canon TR8622a, follow these steps:
  • Press the Home button on your printer.
  • Use the arrow keys to navigate to Settings and select it.
  • Scroll to Fax Settings and press OK.
  • Look for the option to Disable Fax and select it.
  • Confirm your selection and exit the menu.
This will prevent the fax function from interfering with your phone calls. If you need further assistance, don't hesitate to reach out!
Thank you. I will see if that option is available in the settings.
I have not set that receive mode. I will look for that option and see if I can figure it out.
