PIXMA TS3522 prints blurry print
sjbeaok
My canon PIXMA TS3522 printing the Blurry print why?
1 REPLY 1
DerrickL
All prints blurry black and color? That helps narrow it down to one or both cartridges causing the issue, especially if they are not Canon cartridges. There are some steps you can take that can fix this issue:
Causes of Blurry Prints on Canon PIXMA TS3522
If you need specific directions let us know.
Blurry prints from the Canon PIXMA TS3522 can result from several common issues. Here are the main causes:
Low Ink Levels
  • Insufficient Ink: Low ink levels can lead to faded or blurry prints. Even if cartridges appear to have ink, they may not have enough pressure to spray ink cleanly.
  • Check Ink Status: Access the printer's settings to check the ink levels. If any cartridges are low, consider replacing them.
Misaligned Print Heads
  • Alignment Issues: If the print heads are not properly aligned, it can cause misprints and blurriness.
  • Alignment Check: Perform a print head alignment through the printer's maintenance settings to ensure proper functioning.
Dirty Print Heads
  • Clogged Nozzles: Dust or dried ink can clog the print heads, affecting print quality.
  • Cleaning Process: Run a print head cleaning cycle from the printer's maintenance menu. This process helps clear any blockages.
Recommended Steps to Resolve Blurriness
Step Action
1. Check Ink Levels Access settings and verify ink status.
2. Clean Print Heads Run the print head cleaning cycle.
3. Align Print Heads Perform print head alignment if necessary.
4. Test Print Print a test page to check for improvements.
By following these steps, you can address the common causes of blurry prints and restore the print quality of your Canon PIXMA TS3522.
