05-08-2024
10:57 AM
08:14 AM
James_C
My PIXMA TS3522 randomly started having an issue with feeding the paper in properly. It doesn't get jammed or stuck in the printer, it's just only pulling the paper in about 1/3 of the way and then nothing after that. The printer still continues to attempt printing onto the paper until I select to cancel the print job. Any ideas as to how to fix this? I've seen where some said they could manually feed the paper in themselves but no luck there either. It will not feed the paper in any further than the initial section. I've cleaned the paper feed rollers as well as checking for anything stuck in the paper section and found nothing. #pixmats3522 #ts3522
05-14-2026 04:42 PM
To clean the paper feed rollers on a PIXMA TS3522, first ensure the printer is on and remove any paper from the rear tray. Then, press the Setup button until "7" appears on the LCD, followed by pressing the Black or Color button to clean the rollers without paper, and finally load a sheet of plain paper to complete the cleaning process
