PIXMA TS3522 How to scan documents into computer
Mcruz63
Hello, need help here! I need to scan documents into my pc and I don't see any button to scan my documents. And i really need help because this for an important matter and I can't figure it out. Please help someone
14 REPLIES 14
I figured it out after I posted my question, but thanks very much.
Instructions are here:
https://ij.manual.canon/ij/webmanual/ScanUtility/W/TS3500%20series/1.1/EN/SU/su-102.html
No1KCfan
Thank you very much.
BeverHer
I had this issue but with a little digging I made a discovery if you push the i button that is on the printer below the wireless button it will print out a network configuration page three to be exact. If you look through the first page under Wireless Lan which is marked as number 3 on the list it has the WPS PIN code and that is what you need to be able to scan stuff to your computer. Hope this helps someone not have to go searching for answers to far like I did.
ballhawk
What worked for me was going to the scan utility, Document (PDF) button (2nd from top right), then scanning the first page, removing it, placing the next page on, hitting "Scan" again, rather than "exit", continuing until all the pages had been scanned, then hitting "exit", and they were to the PDF editor.
My pages were upside down, so I rotated them in the PDF editor, then saved the document, and it was as intended.
The instructions were pretty awful
