08-22-2023
06:41 PM
09:56 AM
Hello,
I have a TS3500 series printer, and I was wondering if there is a setting to go to so I only use the black ink cartridge? I will always print B & W but the printer continues to use the color ink cartridges as well. I only need to print in black and white and don’t understand why it has to use color ink as well? Thanks for any information provided.
08-22-2023 06:49 PM
Welcome to the forum!
So that the Community can help you better, we will need to know the exact TS3500 series printer model number. Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you
08-23-2023 09:56 AM
Thanks! No, this isn’t time sensitive, just curious if there is a way to only use black ink, or is it predisposed to use both inks so you’ll have to eventually buy both regardless if you only print in black and white. The printer in the TS3522.
08-25-2023 12:46 PM
If you are printing from a Windows computer, you can configure the driver to print black ink only. Please click HERE for more information.
08-25-2023 01:03 PM
Thanks, but I generally print from my iPad, sometimes an iPhone. Do you know if there is a way to configure black only through the iPad? I have tried looking but to no avail.
08-25-2023 02:26 PM - edited 08-25-2023 02:26 PM
There is no option on iOS devices to set the printer to use the Black ink only.
