04-06-2021 09:30 PM
Hey, y'all, I'm attempting to reinstall my wife's printer on my Windows 10 desktop. Things got pretty dicey with it, and I just uninstalled the device. But upon reinstalling, I'm getting duplicate devices - Copy 1, Copy 2, Direct-This, Scan-That, etc. I want to do a CLEAN, FROM-SCRATCH reinstall of the device, the drivers, the support software, the little shortcut icon on the desktop, and that's it. How do I blow away everything and start from scratch, as if it's never been here before?
For example, right now, I clicked "Add A Printer", and I'm getting three different choices:
Which one should I choose?
05-19-2021 01:55 PM
Hi JimSpy,
The "access denied" error is fine. You will see that the printer is removed from the list.
Once you remove from that window, and uninstall the driver from the Control Panel, it is uninstalled.
04-09-2021 03:55 PM
Well, now, don't all answer at once!
04-22-2021 03:06 PM
Hi JimSpy,
Reinstalling will resolve this issue. To do this, please follow these steps:
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon TS8100 series and left click on Remove device. Repeat until all TS8100's are removed.
5. Click 1 time on one of the other printers installed.
6. At the top, click on Print Server Properties.
7. Click on the Driver tab.
8. Click on the TS8100 in the list. Click the Remove button at the bottom.
9. Choose Remove driver and driver package and click OK.
10. Click Yes and then Delete.
11. Repeat until all TS8100s are removed from the list.
12. Click Close to close that window.
13. In the upper left corner, click on Control Panel (or the Back button).
14. In Control Panel, click on Uninstall a program (or Programs and features, depending on your view).
15. Click once on "Canon TS8100 series MP Drivers" and then click Uninstall at the top.
16. Follow the on screen prompts to uninstall the driver. When you click Complete, the driver is uninstalled.
17. Once done, please reboot your computer.
When your computer restarts, we will reinstall:
1. Please use the following link:
2. Click the Select button next to "TS8100 series MP Drivers Ver.1.02 (Windows)".
3. Click the Download button. The drivers will download.
4. Once the download is complete, open your downloads folder. To access this, press CTRL and J, then let both go.
5. Double click "mpnp-win-ts8100-1_02-ea34_2.exe" to begin the installation.
6. Follow the on screen prompts to reinstall.
04-23-2021 03:13 AM
Thanks for stepping up, Patrick. I appreciate the clear and concise instructions.
I succeeded in performing steps 1 - 9. But instead of confirming deletion, I got the following error:
The following package(s) can not be deleted:
ts8100p6.inf (x64)
This package contains the following driver(s) that are in use:
Canon TS8100 series; This driver is used on:
Canon TS8100 series (Copy 1)
Canon TS8100 series
The following driver(s) can not be deleted:
Driver Canon TS8100 series (x64) is in use. It is used on:
Canon TS8100 series
There was a "copy 1" but I definitely deleted both TS8100 devices from the list.
What should I try next?
04-25-2021 05:16 PM
04-28-2021 04:07 PM
Hi JimSpy,
Please reboot your computer and try again.
If the issue persists, there may be old print jobs left in the print spooler. To remove these, please view my post here:
Once you have the Print Spool service back on, please follow the steps above.
04-28-2021 08:06 PM
OK, I rebooted the computer. No love.
I followed the instructions in that link, then picked up where I left off. This time I got a little further, but am up against another error:
Failed to remove package ts8100p6.inf. Access is denied.
So I think it deleted the driver but not the software package. How do I give myself access to delete the package? Or is that just a stray file that I can ignore/work around?
05-19-2021 01:55 PM
Hi JimSpy,
06-14-2021 12:59 PM
Hang in there, I just got back from a long RV trip. Give me a day or so to recuperate.
05-03-2022
10:15 PM
10:31 PM
StevenMOD
Hi Patrick,
Your step by step instructions are just what I was looking for. I have successfully followed them but for unknown reasons during the install I am not able to get past "12" of the 14 steps. On one of my several attempts something popped up on the task bar that I clicked on and it allowed the installation to continue and finish 14 of 14 but then the printer failed to connect to my network and I have yet to figure that out either. Yes, I'm dealing with two separate issues and I'm hoping that you can help me with both. Thanks in advance. Jerry.
