04-06-2021 09:30 PM
Hey, y'all, I'm attempting to reinstall my wife's printer on my Windows 10 desktop. Things got pretty dicey with it, and I just uninstalled the device. But upon reinstalling, I'm getting duplicate devices - Copy 1, Copy 2, Direct-This, Scan-That, etc. I want to do a CLEAN, FROM-SCRATCH reinstall of the device, the drivers, the support software, the little shortcut icon on the desktop, and that's it. How do I blow away everything and start from scratch, as if it's never been here before?
For example, right now, I clicked "Add A Printer", and I'm getting three different choices:
Which one should I choose?
05-04-2022 04:11 PM
Hi Dabuzzer,
First, let's connect your TS8120 to your wireless network:
1. Select Setup on the Home screen (it is the gear icon at the bottom of the LCD screen)
2. Select Settings
3. Select Device Settings
4. Select LAN settings
5. Select Wireless LAN
6. Select Wireless LAN setup
7. Select Manual connect
8. Select your wireless network name from the list that appears
9. Enter your wireless network password
Select OK when "Connected to the wireless router" appears.
Were you able to connect your PIXMA TS8120 to your Wi-Fi?
05-04-2022 07:15 PM
Hi Patrick,
Thanks so much for the quick response. Everything worked great right up to step 8. After selecting the network that I know 100% is up and running and working great BUT, the printer gives me a message that it can’t connect or it failed to connect and I need to restart the network. I went through that process a half a dozen times and still no request for the password. Is it possible that the Wi-Fi is disabled in the printer? Just a thought but I can’t seem to find a way to “turn it on”. What can I try next?
Jerry
05-06-2022 12:52 PM
Hi Dabuzzer,
Some routers do not allow the printer to connect using this method. Examples of this would be Hitron or ARRIS.
In this case, please use the WPS method to connect your PIXMA TS8120. There are two types of WPS connection methods that can be used, I've included both below:
Connect using WPS Push button method
Connect using WPS PIN code method
