12-29-2024
07:29 PM
08:25 AM
James_C
I'm running the nozzle test pattern and most of the colors don't show up at all or show up with some few streaky lines. I've run the nozzle cleaning several times and it's gotten worse
12-30-2024 08:56 AM
If you have run several deep cleanings and that hasn't corrected the problem the print head would most likely need to be replaced. Is the printer still under Canon warranty?
