TR8620a cannot be found by drivers
etfloyd
I have purchased a second TR8620a after the first had a clogged print nozzle that could not be fixed.
When running the recommended install drivers the wizard cannot find the printer on wi-fi (I can manually connect it to the network from the printer itself) OR when hardlined with an ethernet cable.
I have tried installing the connection assistant driver and it, also, was unable to find the printer.
I have uninstalled and reinstalled all canon software on my pc several times.
I have restarted the router.
I have restarted the pc after every uninstall.
I have turned off firewalls.
I do not have an isolation feature activated on my router, nor do I have "ActiveArmor" enabled (AT&T router/modem).
The PC can connect to the printer if I add a printer via Devices and Printers in the control panel.
I need this printer for the scanner function for my business.  I CAN print documents, but I need to also be able to scan documents to my computer, not to the cloud (i.e. Google Drive etc.).  The driver wizard does find the printer if I install using a USB cable, but even with the USB cable the printer still cannot find the pc to scan documents.
I do not understand why this printer is unable to find the PC. Please help before I metaphorically flush my money down the toilet by shooting my new printer into space.
1 REPLY 1
Moderator
Moderator
Thanks for joining the conversation, etfloyd!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter and you're in the United States, we recommend giving our PIXMA support team a call at 1-800-OK-CANON (1-800-652-2666).  They're available Monday through Friday.
Thanks and have a great day!
