Ports are Important for a stable network connection
TommyZulu
If you use Windows, the software will often connect you to a WSD port which is pretty unreliable. If you want a more stable network connection I suggest using the printer's IP address to create a TCP/IP port and connecting it to that.
If it reasonably straighforward.
2 REPLIES 2
normadel
There are other connection protocols used with Canon printers.I've been doing this a long time and still don't know what the WSD thing is.  I find two printers being installed,,,,WSD and IP. I delete the WSD printer.
IP is not always a choice to make but if it is there, it's what I always use.
jadotex513
Hello,
Great tip—WSD ports can be flaky. Setting up a TCP/IP port using the printer’s IP address is a more reliable and straightforward way to ensure stable connectivity, especially in networked environments.
Best Regards,
Jadotex Henry
Friends and Family
