06-24-2014 09:58 PM - last edited on 08-11-2022 08:10 AM by Danny
My pixma MX922 is not printing black text. It will print color. I have changed my ink, cleaned it and shut it on and off. Thoughts?
05-28-2018 12:33 PM
my mx922 will not print black in photos. so weird..it shows it all messed up. like a ghost filter
05-29-2018 03:54 PM
Hi samor23,
Let's start by performing a nozzle check to make sure that the ink is being properly distributed. Full instructions for performing the check can be found HERE.
If the black grid pattern or any of the color bars are streaked or missing, a cleaning may be required.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
05-29-2018 04:34 PM
Hi BillS,
I've done what you advised and the black for text still didn't print. I took the head out, flush the ports until the water ran clear, put it back into the printer with new ink cartridges and still blank. It will print photos only.
05-30-2018 09:41 AM
Hi Mememe1,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
06-27-2018 05:48 PM
I found a solution that might work for some of the users within this long thread.
I have a MX922 and my problem began yesterday after years without issue. I don't know if starting to use Windows 10 this month (new PC purchase) has anything to do with it.
Black would not print a pdf document, even after changing the PGBK cartridge (BK was full) and doing a number of the tests.
A few minutes ago, I decided to just open an email and print it. It worked fine. Right after, I retried printing the problem pdf doc. It worked perfectly. Dumb luck ? Try it.
08-06-2018 01:00 PM
To All:
I figured out two temporary emergency solutions to this problem.
• My first very simple solution was to change the color of my text to a very dark navy blue. This printed my document but the color was a dark blue.
• Second solution. I noticed others were able to print photos OK but not text. So I changed the "Media Type" from plain paper to "Photo Paper" and was now able to print perfectly using black ink.
12-19-2018 05:58 PM
I have also found a work-around on my MP520. In my case half of the black type is missing. If I put the Printing Preferences on HIGH QUALITY, the black prints fine.
My settings screen on the printer works 1% of the time, that's also a pain. I do not wish to live in a disposable world.
11-13-2018 08:47 PM
I bought last June 2018 a Canon PIXMA G2010 and recently the printer doesn't print black text or I can see nothing at all in my paper. The colored inks are working. I tried cleaning it once or twice by following the "Maintenance" procedure in the manual but still the black text printing doesn't work. I even refill the blank ink tank up to high level even the tank shows the level is still at the middle between high and low. What will I do?
12-27-2018 03:45 PM
Is there a solution?
01-09-2019 01:28 AM
I have the same issue with MX922 model. Looks like massive defect for the same series of printers. So far using the "photo paper" workaround. Very disappointed with Canon and looking to buy more reliable printer from one of Canon's rival.
