01-23-2013
07:13 PM
10:36 AM
I keep getting an error message that says the rear paper is jammed. There is no paper in the machine anywhere. This printer is only a month old.
06-28-2022 11:07 PM
same problem, MG7720
problem is, I had planned my next printer won't be another canon and I just spend money on new cartridges... this printer has had more problems with paper jams than any previous printer... and has more problems with limited paper sizes
my old PIXMA could print anything, this one... I spend too much time researching problems. Today, the microsoft notification was opening again and again, every ten seconds so I finally turned the notification off
**bleep**, what a choice... more years of struggling with the printer or waste the cartridges I just put in it and have have for my next use. It's old enough it is out of warranty and probably not worth paying to repair.
printer is old enough I don't mind replacing it but, how to shop for a similar printer I can use my current cartridges in?
06-30-2022 02:32 PM
You would qualify for the Canon Upgrade Program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
They would also be able to check if any of the printers in the upgrade program can use the same ink that you already have.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
06-30-2022 04:07 PM
Thank you, I will save that info
tried printer the next day, I was not able to see a deposit slip ( the paper I was trying to print) with a flashlight, all trays out, turning the printer upside down... I really searched for paper...
turned it on the next day thought I would give it one more try and it started up and spit out an unprinted deposit slip....
**bleep**, why wouldn't it do that earlier? and, wasn't jammed was it?
so, now it is happy....
Q, how do I remove paper I can't see? where was it?
and how do I print a small paper?
one of my disappointments with this printer, with my old PIXMA, any size paper went into the upright (if I remember correctly) paper feed and went through the printer without a problem... Several people I know purchased one because I made forms for them for various work needs and my printer would handle it
I could print small envelopes, deposit slips, gift tags... anything
I can't remember every spending as much time trying to remove jammed paper as I have with the MG7720... prints beautifully, when it will print
can't figure out how to shop for a printer what is more accommodating and
how to not waste expensive cartridges when it is time to change to a new printer
can you advise? it would be helpful... Thanks
