03-11-2015 07:25 PM
I need to use a password to log onto a wireless network which has letters and numbers. The letters are the easy part but how do you get the keypad on the printer to give numbers. The password is: abc261 (example only) they key pad does the "abc" part but how do I get it to add the number "261"? Your help would be appreciated. Thank you.
03-12-2015 06:47 AM
This might help
Press the SETUP button on your printer's control panel.
Using the arrows, select DEVICE SETTINGS, press OK.
Select LAN SETTINGS and press OK.
Select Wireless LAN Setup and press OK.
If a message appears to press the WPS button, press STOP to cancel.
Select STANDARD SETUP from the next screen that appears and press OK.
Highlight your access point or router and press OK.
Press OK again to confirm the access point name.
Enter your passphrase using the keypad to the right.
At the screen where you enter your passphrase, in the top right corner of the LCD screen you should see a :1 . This indicates that you are in numeric entry mode. If you press the asterisk key (*) it will switch to :A or uppercase letter mode, pressing asterisk again with switch to lowercase letter mode. To enter a letter in either letter mode, you will press the associated number key to cycle through the available letters. For example: To enter a letter "c", you will press the "2" key three times.
Press OK when done.
The LCD screen will say "Connected" if the password is correct.
03-12-2015 12:31 PM
Thank you, that should fix it. I tried various keys but did not try the "*" to go from numbers to letters. 🙂
@jrhoffman75 wrote:This might help
Press OK when done.
Thank you that should fix it. I tried a lot of eys but missed the asterisk.
