PIXMA MP160 Borderless printing washes out image
baga
I have a MP160 (Pixma Series) that works very well.
Today I've tried to make some bordeless printing and when I use this option — changing Paper Size from A4 to A4 (borderless), the colors of the images fades a lot, resulting on a very light printed image.
If I choose back the simple A4 (with borders), the images prints well again.
I found a way to resolve this, by changing Media Type from Plain Paper to Photo Paper Pro (Media Type under Quality & Media options) and changing Print Quality to High instead of Standard (this option is grayed out for Plain Paper when I set A4 bordeless). But this workaround makes the printer velocity goes down a lot, using more ink (I'm assuming that), even this printing a very little lighter imagem than the A4 Standard print quality.
Is there a way to solve that, printing borderless on standard quality?
I'm on Mac osX 10.8.5, printing from Preview app.
Thanks,
baga
15 REPLIES 15
Im having the exact same issue with myMG3550. the normal print is beautiful and bright but as soon as i click borderless its dull.
shelleym
Shelleym: That is hugely closer in quality than what I'm seeing... almost wonder if adjusting color settings could fix that. Although just switching to borderless should ideally not change the color quality at all. Just the print size.
When I print borderless on PIXMA MP470 it comes out at about 50% brightness. VERY FADED.
WS_Rec
Same issue with my Pixma G3000 series ink tank. A huge difference between A4 and A4 borderless prints, no change in the remaining settings.
Using my wife's MG4250 printer in the UK I experience exactly the same issue - plain A4 paper with borderless setting checked produces washed out colour, changing the setting to uncheck borderless with the same paper and image results in full colour.  Canon does need to recognise this and not just pretend it is not happening.
I have the same issue with my Canon Pixma TS8050 just purchased here in the UK. Dismal performance and such a disappointment. Also, the printer will NOT print to A4 borderless plain paper. It insists on leaving a border.
The little man screwed by the vast corporates yet again, and I'm not even a leftist.
Avatar
