12-27-2023
11:49 AM
12:19 PM
Our PIXMA cannon printer has a Error code locked in paper output slot The paper is jammed clear the output slot and press on.
there is no jam in either the input or output slots. This error will not go clear. we are unable to print.
12-27-2023 11:52 AM
Thanks for joining the conversation, WillK!
So that the Community can help you better, we need to know exactly which Canon printer model you're using, along with the error code it is displaying. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-27-2023 12:17 PM
Thankyou Kristoff for helping us clarify our printer description. We have a Cannon MG6220 printer, unfortunately there is no Error code number on the display.
WillK
12-27-2023 12:19 PM
Thanks for letting us know what Canon product you've got. The PIXMA MG6220 is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
05-29-2024 06:37 PM
Did you ever get a response or find resolution that didn't require an upgrade or new product? I'm having the same issue but no I don't need anything other than a way to just clear the error code. I've turned it off, I've unplugged it… There is no jam, I removed it. I cannot use the printer with the error code still showing
