01-16-2021 08:08 PM
Hi, I recently changed the ink and now the black prints blurry or like double vision. I've cleaned the print head and ran a deep clean but still having the same problem. Can anyone shed some light on the solution? And where is the endcoder strip?
01-16-2021 08:22 PM
Here are instructions on cleaning the encoder (timing) strip:
Click here to view an enlarged view of the timing strip.
The timing strip is a clear, plastic strip approximately 1/4 inch in height positioned horizontally across the center of the unit, just in front of the carriage drive belt. The timing strip contains many thin black vertical lines that help determine the carriage position during operation.
During certain uncommon tasks such as the removal of a paper jam, it is possible to inadvertently touch a lubricated area on the printer's chassis causing a small amount of grease to be deposited onto the timing strip.
Grease on the timing strip may result in poor print quality including; mis-aligned or distorted characters, vertical lines or, in some cases, an inoperable error condition (such as 5100) or knocking / grinding noise.
In most cases, it is easy to remove the grease from the timing strip using common household items. If you wish, you may follow the steps below to remove the grease from the timing strip.
Items needed:
-Clean, unused cotton swab
-Small amount of Isopropyl Alcohol or window cleaner
-Flashlight or other light source
Note:
| Carriage is centered |
| Carriage is to the right |
Note: The timing strip is a clear strip located in front of the carriage drive belt.
Note: If Isopropyl Alcohol is not available, you may use window cleaner solution.
Important: Do not remove the grease on the chassis (metal rail).
Note: After the printer is powered back on, you will receive a message on the printer's display that the printer was not properly turned off. Tap OK to clear the message and return the printer to standby mode.
01-16-2021 08:22 PM
Items needed:
Note:
02-13-2022 12:23 PM - edited 02-13-2022 12:34 PM
So, this actually worked. My print was coming out terrible. Words left unprinted, fuzzy. I ran every maintenance utility, deep clean, prin align, roller head etc all to no avail and no improvement on the terrible unreadable print. Then I found this page after a search and.. 👌 You have to look a bit for the clear 1/4 plastic strip... I used a q-tip dipped in alcohol and ran it all along that strip (followed directions exactly). I told my Husband that I very much doubted this would fix the problem. I saw nothing on the strip that looked dirty and no greasy deposits.. However, I plugged the machine back on and printed a page. To my amazement, a perfectly printed crisp print. Hooray!!
02-13-2022 12:32 PM
If you are having blurry or missing print. Do this! It actually 100% fixed the issue. I was so doubtful this would help the problem, and so relieved when it worked. I thought the printer would need to go to a repair tech or I’d have to throw it away. Thanks for these instructions!
02-22-2023 04:22 PM
Did not work for me! Still blurry!
02-24-2023 02:14 PM
Since the cleanings did not resolve the issue, the printer would need to be replaced.
If the printer is in it's 1 year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
If the printer is out of warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
01-16-2025 11:30 PM
how does one getaccesss to the images in this solution - It directs me to a salesforce page to 'sign-on' and neither my canon support ID no the Community id works on that salesforce sign on page - hence I don't see any of the images for this solution. help
