02-01-2026
07:48 PM
03:23 PM
James_C
Hello. I need some big help in determining why my Canon Pixma MG2522 is stopping a printing que mid print! If I may explain, I have the correct ink, zero paper jam, etc., and updated all drivers only to have this problem occur over and over. I bring up a document to print, cue it to print and when it sounds like the ink cartridge is moving, like in previous usage, the paper feeds as to print and then...it stops mid print and the que prompt to print disappears and the end of printing. I must have googled why a dozen times to no avail. I tried to attach a video of the problem and but don't know how. 😞 Thank you!
02-02-2026 10:53 AM
What type of printer connection are you using? What operating system are you using? When the printer stops does it feed the paper through?
02-02-2026 10:45 PM
Hi Derrick and thanks for your reply. Well its wired with the required cable and usb and not wireless as this model is a couple years old. I have windows 10 as well and all worked as it should for the longest time until recently. When I cue up a document, etc., to print, I can see and hear the printer in action and when it goes to print and the paper goes to feed through, it only does slightly and then it stops mid feed and the printer/ink que prompt window goes away and stops and nothing happens. Sorry but that is the best way I can describe it dear. 😞
02-03-2026 09:41 AM
It could be a windows 10 print spooler problem. Stopping, clearing and restarting the spooler might help:
If the print jobs do not clear, you may need to restart the Print Spooler service:
02-03-2026 09:49 PM
Derrick I followed your instructions....with the same results. Ugh. I even tried to forward a paper and when it sounds like it's going to, it stops. I can recognize the sounds like the printer wants to print....but then it just stops. There are no flashing error lights and I'm left scratching my head. I am able to still scan documents etc., just not print. SMH.
02-03-2026 10:01 PM - edited 02-03-2026 10:03 PM
Can you print from the printer itself? Let's find out.
02-03-2026 10:19 PM
I did just that....and...same thing....it just...stops. I can hear the cycle and even the cartridge moving...but when it is supposed to print/feed....it stops.
02-04-2026 01:48 AM
Well, if the printer won't complete a page (nozzle test, cleaning page,network properties, whatever) even from the printer control panel, it has a mechanical or electrical problem.
Call Canon Support to see if they can be of help with troubleshooting, repair service, or discounted replacement.
