02-02-2026
02:37 PM
03:23 PM
James_C
Canon MX922 Scan does not work on Win 11... I tried various options. No success
02-02-2026 03:35 PM - edited 02-02-2026 03:37 PM
You'll need to install drivers in order to print and scan.
If you are connecting via Wi-Fi, connect your printer to the same wireless network as your computer and run the installer provided below.
If you are using a USB connection, run the installer below, but do not connect the printer to your PC until prompted to do so by the installation utility.
Note, if you are using USB and connected the printer before running the installer, you will need to unplug the device from your system, remove the failed printer instance from the printers applet (under Settings), uninstall any software from Programs and Features, and important restart your system before starting again.
MX 922 print and scan installer - Windows 11
This file is a driver for Canon IJ multifunction printers. You can install the following items of the software:
MP Drivers: The driver for Canon IJ multifunction printer.
IJ Scan Utility: The software that allows you to easily scan photos, documents, etc.
IJ Network Tool: The software that performs the setup for printing in the network connection.
IJ Scanner Selector EX: The software that performs the setup for scanning in the network connection.
Hope this helps.
02-03-2026 04:35 PM
02-03-2026 06:41 PM
Wonderful, please mark my reply as the solution using the drop-down arrow to the right. You can select that option from the context menu that appears.
Hope this helps.
02-03-2026 04:35 PM
Yes it did... MANY thanks
02-03-2026 06:41 PM
