Safari error message after changing PIXMA G6020 ECO setting
drbrellie
I set The ECO setting to OFF for double sided
i went to the utilities on the app and got this message
Safari can't open the page.
The error was: "Navigation failed because the request was for an HTTP URL with HTTPS-Only enabled".
i do not know what to do
please help
thank you
3 REPLIES 3
DerrickL
Try it this way:
Turning Off ECO Settings for Double-Sided Printing on PIXMA G6020
To disable the ECO settings for double-sided printing on your PIXMA G6020, follow these steps:
Accessing the Setup Menu
  1. Ensure the printer is powered on.
  2. Press the Setup button on the printer's operation panel.
  3. The Setup menu will appear on the screen.
Adjusting ECO Settings
  1. Navigate to ECO settings using the arrow keys and press the OK button.
  2. Select EnergySaveSettings and press OK.
  3. Change the setting to OFF to disable automatic power-saving features.
Setting Double-Sided Printing
  1. Still in the ECO settings, look for 2-sidedPrintSetting.
Press OK and select the option to disable two-sided printing if it is set as default.
I followed your steps multiple times and it is still printing double sided. Any other suggestions would be most welcome.  Thank you. I thought I had it
DerrickL
Try a factory reset:
To perform a factory reset on the Canon PIXMA G6020, go to the Device settings in the Setup menu and select the option to reset settings. This will return all settings to default, but you may need to set up the printer again afterward.
Friends and Family
