PIXMA MG2522 Can't Get It To Connect To My Computer
dfulz0203
Just bought a Canon Pixma MG 2522 printer and I cannot get it to connect to my computer to print anything.  I have double checked everything and still cannot get it to work.
3 REPLIES 3
Moderator
Moderator
Hi!  You'll find everything you need to get your PIXMA MG2522 set up right HERE.  If you need additional help, please let us know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof) and how you're trying to connect it to your printer (i.e. via USB cable or via Wi-Fi). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
The problem isn't the set up. The problem is the installation disk takes a dump and stops working. I downloaded the online drivers and they do the same thing - just stall. The printer has power and is connected via a USB cord. My computer cannot see it. Windows 10 computer. Every other printer I've ever had my machine recognized it automatically. The only unusual thing is I'm using an extension usb cord, but it worked fine on my previous (canon) printer.
JayC1
Hi Terris! Thanks for posting in the Canon Community Forum. I see that you are unable to install your Canon PIXMA MG2522 on your Windows 10 computer.
When the printer is not being detected, I recommend uninstalling the printer driver, restarting your computer, and then reinstalling. While you are in the process of reinstalling, it is important to keep the USB cable disconnected. Do not connect the cable until the setup program asks you to turn the printer on and connect the cable.
Here are a few other helpful hints:
  • Make sure that you are using a single USB printer cable that is no longer than 6 feet.
  • If you have security software installed on your computer, we recommend disabling it while the setup program is running.
  • If the printer is not being detected by the setup program, please connect the USB cable to a different port directly on the computer (if available).
  • Do not connect the USB cable to an external USB device that is connected to the computer.
  • If you have a desktop computer, please use one of the USB ports located on the back of the computer.
Please follow these steps to delete the printer and uninstall the driver:
  1. Turn the printer off and disconnect the USB cable. Leave the cable disconnected.
  2. Right-click on the Windows Start icon (the left-most icon in the bar at the bottom of the computer screen) and select RUN from the small menu that opens.
  3. When the Run window opens, type the words <  Control Printers  > in the box and then click on OK.
  4. When the Devices and Printers window opens, right-click on the icon for the MG2500 series printer and select REMOVE DEVICE to delete the printer. If there is no MG2500 series listed, go to the next step.
  5. Close the Devices and Printers window.
  6. Right-click on the Windows Start icon (normally located in the lower left corner of the computer screen) and select RUN from the small menu that opens.
  7. When the Run window opens, erase the words Control Printers and type the words <  Control Panel  > in its place. Then click on OK.
  8. When the Control Panel opens, click on UNINSTALL A PROGRAM or PROGRAMS AND FEATURES.
  9. When the list of programs opens, right-click on the Canon MG2500 series MP Drivers and select UNINSTALL.
  10. Follow the on-screen instructions to uninstall the MP Drivers.
  11. Once the MP Drivers is removed from the list, close the Control Panel.
  12. Restart your computer.
When your computer has finished restarting, please open the following website:
https://www.usa.canon.com/support/p/pixma-mg2522
After the web page opens, please click on SOFTWARE & DRIVERS to the right of the picture of your printer. Then, look for the detected Operating System and Version below the section titled Downloads. Please make sure that you see Windows 10 under Version.
Below that, you’ll see a list of Software & Drivers (showing 8 options). Please look for the MG2522/MG2525 MP Drivers Ver. 1.02 that is 14.90 MB. It is the first one on the list.
Please click on the DOWNLOAD button to the right of the MG2522/MG2525 MP Drivers Ver. 1.02. When it finishes downloading, please run it and follow the instructions. Please do not connect the USB cable until that program tells you to turn the printer on and connect the cable.
When the installation is complete, you will be able to use the printer.
I hope this information helps. Thanks for choosing Canon.
