PIXMA MG2500 Series - The bottom of the page always cut off
AR1515
Does anyone know how to reset the default automatic margins on Canon PIXMA MG2500 series driver?
I've been changing all margins on my documents to 0cm, but there ll be always margins showed up when I printed the documents, especially the bottom so it's always cutting off the bottom of the page. So I know it must be the driver. The automatic margin that always showed up on the bottom of the page is around 1,6 cm. There's also no option on the Printing Preferences to change them. I'm using Windows 10, by the way.
57 REPLIES 57
Thank you for pointing that out!
We'll update that old link with this current one: http://canon.us/SupportCF
Thanks again!
This SAVED me! Canon PIXIMA MG2522 was cutting off the bottom of every document. I tried everything from manually aligning the printer head, hard reset, adjusting margins, you name it! I down loaded the adobe PDF reader app for free and no more cut off margins! Thanks for the tip, I now realize Chrome was not the best browser for this printer.
No. This does not work.
Sctt2525
If so many people are having this same problem, Canon should issue a recall or find a real solution.
I gave up trying on my older Toshiba with win7 and fought thru the headache of downloading the driver to a newer HP with win 11. The results were exactly the same.
Thank you so much! I played with print settings in Adobe Acrobat and it helped! You are my hero!!
I suggest switching the printable area to A4 8.27x11.69 legal and only putting the 8.5x11 page moving the bottom margin into that 0.69 extra inches as i have measured the distance to be 0.66 inches in the program and physically  and leaving that area blank so it literally feeds the non-existent paper for .69 inches inches but prints to the edge (0.66 inches short).
Thanks for your response.
But, I threw the pixma in the trash where it absolutely belongs.
Canon has lost credibility by putting their name on this garbage.
danzevl
I'm prettry sure my next printer will be an eco tank. this was free so ill use it to get my jobs done until I make enough cash to get a new one.
