PIXMA GX6021 not printing any color at all
GrandmaD
My nozzle check test page prints only black.  I have done the cleaning and the deep cleaning multiple times.  I replaced the maintenance cartridge today, did another deep cleaning and ran the ink flush.  Still only prints black.  All three color ink tubes are approximately three quarters full.  I am using a laptop with Windows 11 and using a wireless connection to my printer.  Help?
2 REPLIES 2
DerrickL
Did color ink flush, did any color show up in the nozzle check?
Quick checklist try in this order
  1. Check color ink levels
    • Open printer software or control panel and confirm cyan/magenta/yellow cartridges have ink and are recognized.
  2. Run deep/nozzle check & head cleaning
    • Print a nozzle check pattern.
    • If missing colors, run a deep/extended head cleaning cycle (not just a quick clean). Wait 10–15 minutes between cycles.
  3. Power cycle and reseat cartridges
    • Turn printer off, unplug 1 minute, plug in and power on.
    • Remove each color cartridge, inspect for protective tape/seals, then firmly reseat.
  4. Check for clogged/airlocked lines after flush
    • If you flushed manually, air or solvent may have entered lines. Run several cleaning cycles and leave
    • the printer powered on overnight to allow ink to re-prime.
    • Avoid further manual flushing unless you have a full set of fresh cartridges and know how to purge air.
Thanks for the response.
1. My printer does not have cartridges - it has ink tanks.  They are all showing as at least 3/4 full.
2. My print nozzle check shows only black - no colors at all.  I have run the standard cleaning as well as the deep cleaning.  Waited 24 hours and ran the deep cleaning again.  Still no color printing on the nozzle check.
3.  I have turned the printer off and back on multiple times.  I have unplugged the printer as well.  Again, my printer does not have cartridges, so cannot remove them.
4. I did the ink flush from the maintenance screen yesterday.  Still no color printing on the nozzle check pattern - just black.
Other suggestions?
