07-10-2020
03:56 PM
09:08 AM
Hi All,
Brand new G7020 in place and playing with it to learn how to use the features. What on earth is the "manual duplex" mode I can select in the IJ Scan Utility Light software? Does this mean that I put my stack in the ADF facing up, and then turn it over and scan again to complete the process? Since this places the last page on top after flipping, there must be a built-in correction to sort the pages properly? Really disappointed that there is no auto-duplex scanning (some of my older Canon printers were excellent at this feature that seems to be GONE in IJ printers now), so need to figure this out.
Thanks in advance!
Bill
07-11-2020 01:36 PM
I just found this set of detailed instructions for another printer:
https://support.usa.canon.com/kb/index?page=content&id=ART171047
This will make it MUCH simpler to scan a stack of duplex documents if it works the same on the 7020!
If it works, I will mark this comment as the solution.
07-11-2020 10:51 AM - edited 07-11-2020 10:56 AM
Manual duplex means you have to manually feed the two-sided document, one side, then the other during the scan operation to capture both sides of the page.
Automatic duplex scanning is not gone, its still alive and well. Unfortunately, not on your G7020 which I'm surprised as well since its currently the flagship in the MegaTank line. Must be some type of design limitation. (Manual 2-Sided Scan)
~R5 C (1.0.2.1) ~RF Trinity, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It07-11-2020 11:03 AM
07-11-2020 01:36 PM
04-24-2021 09:29 AM
I looked up your recommended unit for substituting. If it did duplex scanning before, then it doesn't anymore. I wish this wasn't such a hard-to-find feature.
06-08-2021 01:18 PM
So how does the manual duplex scanning work when your document has more than two pages? I can find no reference to multi page manual duplex scanning in any Canon support articles or manuals.
Can you place a 10 page 2-sided document (5 sheets of paper) in the ADF have it scan the front of the 5 pages, reload it to then scan the back of the 5 pages and in the end have a PDF with all 10 pages in the correct order? If so, I can live with this. However, if it instead requires each of the 5 pages to be individually scanned front and back to acheive a 10 page PDF in correct order then I may look for an auto deplex scanning model.
12-07-2021 12:08 AM
Unfortunately, since copying is actually initiated with a scan, so two sided COPYING is also not supported. Since there were so many conflicting reports, I actually called before buying.
Asked the wrong question: "will this unit do automatic two sided printing?" "Certainly it does" was the reply. No mention of copying or scanning. What a waste of money!
01-18-2023 05:11 PM
This solution works also for the canon in Europe the ts7450a. Just place up to 35 pages manuel adf. After scanning the 35 pages the scanning stops and asks to turn the pages and scan the other side of the 35 pages. After this process, the pdf just gives you the complete pages in order. If anyone need a video, please reply
04-23-2021 11:52 PM
I completely agree that it's crazy to pay so much for a printer and not have it be capable of duplex scanning. It's very disappointing. Having looked at the solution given, that printer does not perform duplex scanning either. Hopefully, it's something that can be fixed with a software update.
06-08-2021 01:37 PM
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
